skipper3362 ®   06-Nov-2024 10:39
Multiframe 2024
Year: 2024
Version: 24.00.00.722
Developer: Bentley
Platform: Windows
64-bit OS compatibility: yes
System Requirements: windows 10 and up
Localization: English
Crack: Included
Description: The MAXSURF development team is pleased to announce the release of Multiframe 2024 (24.00.00.722).
This solution helps structural experts check the structure of their vessel to comply with class requirements and optimise it for strength and weight.
It can be used for deck grillage, frame, superstructure and mast strength calculations.
Bentley Lifecycle Policy, version numbering and side-by-side installation:Bentley Systems has made changes to the support lifecycle of desktop applications.
One of the key changes is that major versions of Multiframe will be supported with critical fixes for at least five years, although users are still encouraged to update to each new version to benefit from new features that are added to Multiframe.
The main change is that we will be moving to year-based naming for all products, thus this release is Multiframe 2024.
The version numbering (MM.MM.uu.bb) changes slightly with now the first two digit pairs (MM.MM) indicating the major version number of the software; the next pair of digits (uu) is the minor update of that major release (if any) and the final pair (bb) is the build number.
Major versions continue to be installed side-by-side on the same machine; thus “Multiframe 2024” (v24.00.00) can be installed alongside “Multiframe 2023”.
Minor updates to a major release releases will replace the any existing installation with the same major version number; thus v24.00.01 would replace v24.00.00 but still be called “Multiframe 2024”
.License and Product tier consolidation:From Multiframe 2023 onwards there is only one tier level of Multiframe which contain all features and capabilities.
The License Configuration dialog will continue to be displayed when starting an application primarily for verification of the license status since there are no tier options to select.
Furthermore, both Maxsurf and Multiframe have been integrated under the MOSES brand.
Multiframe provides linear and non-linear analysis, static and dynamic options and buckling calculations.
These analysis options are complemented by a full range of analysis-related modeling tools like master-slave, prescribed displacements, springs, thermal effects, offset members, additional masses and much more.
Other modules allow you to draw sectionshapes and install them in the sections library and perform design checks for a range of design codes.
Multiframe Automation allows you to prepare design calculations in Excel and link them directly with your Multiframe model.
An ever expanding range of design add-ons also allows you to simplify steel code checking and optimization.
Additional info: the programma is in a rar file to protect the patcher
ther patcher can be seen by windows defenfer and antivirus programmas as a virusso keep the rar file alsos backupuse of the patcher is at your own risk
disabler windoes defender ore antivirus before installation and give it a exsecption
Multiframex64_24.00.00.722.rar
Download [40 KB]
MOSES 2024 v.24.00.00.722 - Bentley [2024]
MOSES CONNECT Edition Version 12 v.12.04.00.78 - Bentley [2021]
SACS Connect v.23.00.00.322 - Bentley [2023]
Monopile Designer v.21.01.00.479 - Plaxis [2021]
MoDeTo CONNECT Edition V20 Update 4 v.20.04.00.790 - PLAXIS Bentley [2020]
Lecture Note for Innovative Ship Design - Prof. Kyu Yeul Lee [2012, PDF]
Maxsurf v25.00.00.280 - Bentley [2025]
Strength Analysis of Hull Structure In Bulk Carriers - DNV [2012, PDF]
Application of Higher-Strength Hull Structural Thick Steel Plates in Container Carriers - ABS [2021,...
Bentley STAAD PRO Structural Analysis Design Software [2020, MP4]
The time now is: Today 17:42
